Audience PowerChord SEi
0 Members and 1 Guest are viewing this topic. Read 782 times.
Rivalaudio
« on: 16 May 2020, 10:36 pm »
Up for grabs are my Audience PowerChord SEi
Length: 9 feet
Retail: $1050
I will let mine go for $500 $400
Rhodium plated copper Plug and IEC AC power connectors, High Power, Low Impedance, Multistrand/Flexible, Superior Sound Quality
2016 – Improved wiring configuration implemented to further advance performance of original powerChord SE.
The powerChord SE-i is a low resistance, low impedance design made with the finest conducting and insulating materials available in a rugged, flexible, "user friendly" configuration.
The powerChord SE-i being a low impedance design has the ability to naturally reject noise and interference and it also radiates much less energy. This improves performance and lowers the noise floor allowing for superior reproduction of low level detail as well as dynamics.
The powerChord SE-i has the unique ability to let each type of component perform optimally by quickly providing more power with better quality to your component's power supply. It does so in a flexible, durable, reliable design. In fact, all audience cords and cables are unconditionally lifetime guaranteed. If you return your defective or damaged cable audience will repair or replace it at no charge.
« Last Edit: 30 May 2020, 05:14 pm by Rivalaudio »
Rivalaudio
Re: Audience PowerChord SEi
« Reply #1 on: 30 May 2020, 05:14 pm »
Dropping these to $400!
navrsale
« Reply #2 on: 27 Jun 2020, 08:41 pm »
Is it available?
Rivalaudio
« Reply #3 on: 27 Jun 2020, 09:29 pm »
Yes, I have 2 of them.
