0 Members and 1 Guest are viewing this topic. Read 10310 times.
Scott,> should be factoring in the amount of speaker toe-in when attempting to identify my first reflection point using mirror-along-the-wall method? <No. Just look for places where you can see either speaker, regardless of the speaker cabinet's angle.--Ethan
By nature, that point will be always closer to the speaker than to the listener, but usually about 1/4-1/3 of the distance from the speaker to you along the wall (it could be as little as 1/10th), to get you started. Only if the speaker were directly in front of you would the half way point be valid. Someone skipped geometry!
What I've also done is looked past the front (parallel to the front) of the speaker and ensured that I saw the trap at that location. The only thing I wonder about the posted diagram is that it doesn't take into account the dispersion characterictics of the speaker. Nor does it take into account toe in. For instance, with the RM40s, I would assume there's a relatively narrow dispersion. One would think that if I toe in my speakers a lot (which I do), that I would not put the realtrap at the same locatio ...
John,Ted beat me to it and posted the drawing I would have. > Anyone know if it is accurate in ceiling reflections? <For ceiling RFZ panels the center is halfway between your ears and the tweeter. This assumes the tweeters are at ear level, which they should be.--Ethan
