New Bot
0 Members and 1 Guest are viewing this topic. Read 885 times.
spinner
New Bot
« on: 15 May 2020, 09:57 pm »
 Hi, any word on the new BOT that is using the  LG loader ? I assume it still functions the same as the previous version... Does any one have  the newer unit...thanks :thumb:
unincognito
    • bryston.com
Re: New Bot
« Reply #1 on: 18 May 2020, 05:40 pm »
If you order now you might get one of the last ones.
Chris
jobiwon
Re: New Bot
« Reply #2 on: 9 Jun 2020, 09:06 pm »
I just picked up a used BOT-1 from a dealer.  Sometimes it doesn't recognize a disk and it takes multiple tries before it works.  Then one day during a burn it started vibrating.  I grasped it with my hand and it stopped.  I had to put my vinyl clamp/damper on it to stop it.  Has not done it since.
Can I get some background on what the old loader was and what the "LG" loader is?
product has been discontinued.  Because of poor sales?
jb
