I need help setting up digital audio on RX-F10
0 Members and 1 Guest are viewing this topic. Read 1049 times.
brokenhorse
« on: 22 Feb 2005, 07:23 am »
I read many good reviews about the JVC RX-F10 price/performance.
So I bought one today specifically for the multi component and digital audio inputs. Unfortunately, I am having trouble getting audio from any digital source.
My sattelite receiver has optical audio out which I plugged into the F10's "DBS" optical in. My DVD player has PCM out that I plugged into the F10's "coaxial D1" in. Now when I switch to these sources, I get video but no audio. I went through th menu options and ensured that the correct digital input was assigned to the appropriate devices.
However, when I plug in any analog I get audio without any problems.
Am I missing something?
Any help is greatly appreciated.
Chris
gary
Re: I need help setting up digital audio on RX-F10
« Reply #1 on: 22 Feb 2005, 01:29 pm »
Um, there's an input button on the remote that you might try pressing, it cycles through analog, digital and digital auto. Your receiver might be set to analog. I can't remember exactly what the button is labeled, but I can check when I get home.
Gary
brokenhorse
« Reply #2 on: 22 Feb 2005, 04:16 pm »
Quote from: gary
Gary
Thank you!
Got it.
