Side and rear surrounds for super mini
0 Members and 1 Guest are viewing this topic. Read 913 times.
Ryan0348
« on: 12 May 2020, 02:30 pm »
I’m setting up my system in my new house and have a very large area to use. 25x28ft is the area so I’ll have a lot more room for a surround setup. I have dual h frame subs for the front and 2 rhythmic 12” subs for the rear rear of the room. My mains are super minis and I’m looking for rear and side surrounds to go along with the super minis. I know they don’t need to be the exact same speaker but something with the same timber would be nice. Danny any ideas. Also the rhymic are gonna be ran out of out phase in a pull setup while the h frames push. Right now I’m using a rythmic  lv12 I think is model run out of phase and placed right in the middle of the room behind the couch. Gonna buy one more and space them apart the same as the front. Any ideas for the surrounds. Thanks
Danny Richie
Re: Side and rear surrounds for super mini
« Reply #1 on: 13 May 2020, 04:20 pm »
My favorite surrounds are still the A/V-1RS models. It gets everything up around you and makes a big sound field that is just perfect for applications where space is limited and you just can't get those rear speakers far enough away.
Ryan0348
« Reply #2 on: 14 May 2020, 05:20 pm »
I will plenty of room to get the speakers away. All the way arround. 12ft to each side and 15ft forward 14ft back
Danny Richie
« Reply #3 on: 14 May 2020, 05:37 pm »
If you can set them out into the room then the A/V-O works really well in that application and will really create a large and spacious feel.
Ryan0348
« Reply #4 on: 14 May 2020, 05:39 pm »
Sweet. Ill be in touch in a few weeks. Ill need parts for 3 pairs. Front wide, sides and rear
