ECC86 Sub for 6922 in buffer stage?
0 Members and 1 Guest are viewing this topic. Read 927 times.
Escott1377
« on: 10 May 2020, 01:47 pm »
I was trolling around the internet the other night and came across the ECC86.  I own a Cary 100t DAC that uses a pair of 6922’s in the output stage.
On paper, the ECC86 has the same pin-out, however does not read as a sub.
I would never use it in a gain stage, but since this is just a buffer, curious on thoughts about the swap?
I did a quick check on EBay and the price for the ECC86 is very attractive.
Thanks in advance - hopefully before I fry my DAC :)
shooter
Re: ECC86 Sub for 6922 in buffer stage?
« Reply #1 on: 10 May 2020, 03:26 pm »
The ECC86 has a maximum plate voltage of 30v, not a substitute for 6922, if you want cheap may try 6bz7.
