Box volume change with No-Res?
0 Members and 1 Guest are viewing this topic. Read 804 times.
Bullitt5094
« on: 8 May 2020, 01:09 pm »
Should you increase the box volume to make up for the volume of the no-res you add to it?
mlundy57
Re: Box volume change with No-Res?
« Reply #1 on: 8 May 2020, 01:16 pm »
No. While the damping layer takes up a little of the internal volume, the foam slows down air movement which acts like a bigger box. So the gain from the foam offsets the loss from the damping layer. The result being NoRez is volume neutral so no change in box size is necessary.
Bullitt5094
« Reply #2 on: 8 May 2020, 02:03 pm »
Makes sense. Thanks!
« Reply #3 on: 8 May 2020, 03:56 pm »
That is why  it is important for anyone    making their own  no-rez (heavy floor  tiles/OCF) it is important to use the  open cell foam
jay
AverageNiceGuy
« Reply #4 on: 8 May 2020, 05:30 pm »
Good info, Thanks.
I was wondering about that.
I will be installing No-Rez in some new CST-1's when it arrives.
« Reply #5 on: 8 May 2020, 10:50 pm »
I was wondering about that. I was building a small MLTL unit and opted to not use No-rez on it since the thickness of the turn was only 1". Figured that it would screw up the design. Using 1/2" felt instead, which is what the designer recommends.
I am using the no-rez in my subs and in my woofer cabinet.
