AV2 build ... how to feed it
0 Members and 1 Guest are viewing this topic. Read 1287 times.
Striker071
« on: 8 May 2020, 12:33 pm »
Ok
What is the best way ( I know 10000 tube amp with a 5000 tube pre amp) reasonable way to feed a set of AV2's.  I know budgets are always a consideration and in most things spending more should get you a better product.  I haven't even delved into audio equipment in years and the more I think about it the more I feel little behind the power curve.
just looking for ideas... yes they could include the high-end amp and pre-amp that would have to wait until I can transplant the money tree my father got from my grandfather..(wish he would tell me where it is).
Thanks for the help
Striker
mlundy57
Re: AV2 build ... how to feed it
« Reply #1 on: 8 May 2020, 01:23 pm »
What type of budget are you looking at? There are too many options to list all possibilities. A rough idea of your budget will narrow down options to something more manageable.
Mike
corndog71
  • Some people call me Rob.
« Reply #2 on: 8 May 2020, 03:32 pm »
Is this for a simple 2-channel stereo?
Music only or also for TV / movies?
Striker071
« Reply #3 on: 10 May 2020, 09:10 pm »
For starters I am looking for under $1000.  I think a AV setup might be the way to go
S Clark
« Reply #4 on: 10 May 2020, 10:53 pm »
Used AV receivers are cheap and plentiful.  $50 off of Craigslist should play acceptable music.
Doublej
« Reply #5 on: 10 May 2020, 11:52 pm »
Klaus can build you a cyclops integrated for $1095.
http://odysseyaudio.com/products-cyclops.html
mlundy57
« Reply #6 on: 11 May 2020, 12:19 am »
With that budget you have tons of options. For an all in one piece check out PS Audio’s Sprout 100. Some other options would be offerings from Schiit Audio, NAD, Emotiva, Outlaw Audio, IOTA, etc. With Scott’s suggestion of used equipment the possibilities are even greater. Three places I’ve bought used equipment from are the Trading Post here on Audio Circle, US AudioMart, and Audiogon.
Mike
