X-Voce plans in SAE?
0 Members and 1 Guest are viewing this topic. Read 1395 times.
hawkeyejw
« on: 7 May 2020, 08:23 pm »
Hi All,
I just received an X-Voce kit from Danny and perusing through the plans I see the measurements are metric and utilize a lot of mitered edges. I'm planning to do simple butt joints so before I go about creating a translated plan I thought I'd ask the group here if anyone has already done this work and if so, if you wouldn't mind sharing with me? Thanks in advance!
Jeremy
Creative cut designs
Re: X-Voce plans in SAE?
« Reply #1 on: 7 May 2020, 10:44 pm »
I cant find the plans for that speaker to review it and see if I could give you any advice, atleast I tried
hawkeyejw
« Reply #2 on: 7 May 2020, 11:13 pm »
Thanks CCD! I couldn't help myself so I calculated what I think are the correct sizes and shot them over to Danny to take a look. If they're correct I'll post them with Danny's ok in case anyone else is working on one.
Danny Richie
« Reply #3 on: 7 May 2020, 11:27 pm »
I've been wanting to convert those drawings for a while now. I just have not had time to get to it.
« Reply #4 on: 7 May 2020, 11:29 pm »
Just divide all   mm by 25.4  for  " s
LOL,  I'm in a constant battle  with mm/" 's, would be  better if everyone would  just    use  mm like over  99% of the planet does  :lol:
jay
« Reply #5 on: 7 May 2020, 11:33 pm »
👍hope it all goes well..hawk!
hawkeyejw
« Reply #6 on: 7 May 2020, 11:39 pm »
Danny if the dimensions I emailed over to you are correct I can post them and we’ll crowdsource some plans for you.
mlundy57
« Reply #7 on: 8 May 2020, 02:16 am »
jay
At least in this I can be part of the 1%  :rotflmao:
Mike
hawkeyejw
« Reply #8 on: 8 May 2020, 03:52 am »
I started using a converter to transfer the measurements over but they are slightly off from the normal inch & fraction that we use here. I started to have visions of edges that don’t line up because the geometry no longer matches. So I found an old post of Danny’s with the outer dimensions in inches and used that along with some of the metric dimensions to create what I think are the right overall dimensions. Guess that makes me a 1%er too!
« Reply #9 on: 8 May 2020, 04:25 am »
Mike
Love it, perfect  reasoning   :thumb:
Enjoy  converting  all those  fractions      !!
jay
RusskySam
« Reply #10 on: 8 May 2020, 02:34 pm »
...like over  99% of the planet does
Something, something... founding fathers... exceptionalism... mission from god... :)
