Sold: Paradigm PW streaming amp
0 Members and 1 Guest are viewing this topic. Read 396 times.
Cacophonix
« on: 7 May 2020, 07:22 pm »
SOLD!
A fantastic all in one streaming integrated amplifier with top of the line room correction built by Anthem. This is by far the best integrated solution that you can find at this price anywhere. It has a subwoofer output, and can power any reasonably efficient speaker to loud volume. It is small enough that it can hid anywhere in the room.
Use your phone for room correction using the anthem app or use the included mic and run the room correction on your laptop. The difference is not subtle.
It doesn't come with any remote, and all control via the DTS play-fi amp.
Asking price : $175 + shipping from 75025.
DESIGN
Anthem® Class-D wireless 2-channel amplifier
AMPLIFIER
Anthem® Class-D Amp; 2 x 200W Dynamic Peak; 2 x 100W RMS 4 ohms
FREQUENCY RESPONSE ON-AXIS
+/- 1dB from 20Hz - 20kHz
ROOM CORRECTION
Anthem Room Correction - ARC™, with included calibrated microphone
SENSITIVITY ROOM / ANECHOIC
0.75 Vrms /
IMPEDANCE
Compatible with 4, 6 & 8 ohm speakers
FINISHES
Black & White
WEIGHT
3 lbs. (1.4 kg)
DIMENSIONS HXWXD
3.125" × 5.75" × 8.625" (7.9cm × 14.6cm × 21.9cm)
INPUTS
RCA analog inputs, USB (for firmware updates), Ethernet 10/100, L/R speaker terminals
WIRELESS RECEIVER
2.4GHz and 5.0GHz; 802.11 g/n
« Last Edit: 10 May 2020, 04:35 pm by Cacophonix »
