Question about insulation for speakers
0 Members and 1 Guest are viewing this topic. Read 1130 times.
Creative cut designs
« on: 5 May 2020, 12:13 pm »
Has anyone ever used open cell foam then roxul insulation? It's a sound attenuation? Does anyone have any input?
« Last Edit: 6 May 2020, 12:30 am by Creative cut designs »
mlundy57
Re: Question about insulation for speakers
« Reply #1 on: 6 May 2020, 03:35 am »
Sorry, I've only used NoRez for that
« Reply #2 on: 6 May 2020, 03:41 am »
Thanks atleast you answered 👍I just know roxul is a good sound attenuation material
mlundy57
« Reply #3 on: 6 May 2020, 04:05 am »
NoRez has a dampening layer and a foam layer. It is easy to cut, especially with a table saw, and has a PSA backing. It's super easy to work with.
nickd
« Reply #4 on: 6 May 2020, 04:57 am »
Not sure I would use the Roxul unless you just don’t have other options. NoRez is really good, easy to install and really helps damp lively box walls. I also like cotton acoustic insulation, natural wool and even felt for mid range and mid woofer boxes. Good old fashion fiberglass insulation is surprisingly good for bass.
If you are stuffing boxes to increase the volume the woofer sees for tuning, some trial and error is par for the course. I prefer a correct box tuning than lots of stuffing. Hard to cheat the laws of physics and you can easily “over stuff’ a woofer bin and mess up the sound.
« Reply #5 on: 6 May 2020, 05:00 am »
Thanks for the advice I'm building the av3's
« Reply #6 on: 7 May 2020, 11:37 pm »
For the Av3 TL's ,  I'd recommend   no-rez for damping  the walls, the  install   acusti-stuff in the areas that call for  poly fill.
jay
hawkeyejw
« Reply #7 on: 7 May 2020, 11:59 pm »
CCD no-Rez is really great stuff. Easy to work with and neutral to the air space of the speaker so there’s no impact on tuning. Well worth the price IMO.
« Reply #8 on: 8 May 2020, 12:12 am »
Thanks but from what I hear it's not available
hawkeyejw
« Reply #9 on: 8 May 2020, 12:17 am »
I didn’t realize Danny ran out.
Danny Richie
« Reply #10 on: 8 May 2020, 12:44 pm »
We have plenty of No Rez in stock.
