BDP-2 Ethernet ports
0 Members and 1 Guest are viewing this topic. Read 683 times.
Jaytor
« on: 3 May 2020, 10:09 pm »
How do the two ethernet ports operate on the BDP-2? I'd like to use one to connect to my home network and the other to connect to my Roon Server (NUC running ROCK), but this doesn't seem to work. I had assumed that the BDP-2 would pass traffic from one port to the other (acting like a switch), but this doesn't seem to be the case. What are the two ports intended to be used for?
Thanks.
unincognito
    • bryston.com
Re: BDP-2 Ethernet ports
« Reply #1 on: 6 May 2020, 03:29 pm »
It just a second Ethernet adapter, both have the same behavior.
