0 Members and 1 Guest are viewing this topic. Read 6777 times.
There are a few variables at play, but max output is not one of them unless you are playing it at full volume. Each amp has its own signature tone, dynamics, etc and some have better impedence matching with your speakers than others. And then there are tube choices to consider as well. In other words, there are a lot of variables at play!
Short answer is no. Roll some tubes, try some reissued KT66 Gold Lion power tubes and a good 7DJ8 input tubes instead of the Russian 6N23P's. This combination should work better for you.NB
There is no such thing as too much power. Sure, one could turn up the volume so loud that you blow your speakers, but even then if you tried to do the same thing with a lower powered amp you would destroy the speakers with clipping.I know people running 100dB+ speakers with 300 watt solid state amps. They say the transient peaks are faster, more dynamic and cleaner with high power amps. There is a video from Harbeth where it shows their speakers being driven with amps delivering 800 to 1000 watts. Surprisingly the meters showed peaks of where the amp's output went to over 500 watts. Generally even when speakers can be driven adequately with 2-3 watt amps, they will sound better with 20-30 watts - given amps of equal quality.
Before buying tubes try repositioning the speakers. Don't point them directly at your sitting position, aim them about 1' outside your ears. This will have the effect of reducing treble response a tad. This is how I listen to my Decware SAHO's.HK
maybe the design of your 2w amp is more pleasing at playing the first watt than your other amp? the majority info out there tells you need more power to cover the dynamic range. i've spent a ton of money trying more powerful amps because it what i'm supposed to do then in the end i find that my 2 watt amps are whats best to me.
Other unsuited features are Torii use 4 output tubes which have to be matched since there is no Bias adjusting, so when one or more output tubes are not close paired sound quality suffer.
