Custom Rega Turntable (Price Reduced)
0 Members and 1 Guest are viewing this topic. Read 1394 times.
REY
« on: 28 Apr 2020, 10:20 pm »
 For sale, well, this is what a stock Raga Planar 2 looks after 15 years of upgrades, the suspended original motor was the first thing to go and put a new rega motor (still the AC model), then I rewired the tone arm with Cardas and fitted a Din plug, so you can switch to any cable you want, sorbotane feet, acrylic platter (I dont remember the company name, Deep grove I think), metal sub platter  from England with the corresponding Zaphire ball bearing, custom bronze counter weight (if you take the time to polish it looks awesome, I promise:)) The Nagaoka MP110 has 80-100 hrs maybe, oh the plinth, is basically the original Rega plinth sandwich between two 3/4 MDF pieces, heavy with real wood veneer, I actually have pics of the process if the new owner cares about them. Price $600 shipped  within the continental USA.
« Last Edit: 1 May 2020, 08:08 pm by REY »
onethousandanswers
Re: Custom Rega Turntable (Price Reduced)
« Reply #1 on: 8 May 2020, 09:25 pm »
Are the dimensions of the plinth the same as those of the original Planar 2 (just thicker)? Did you use other carts with the table and if so do you have any thoughts on good synergies? Finally, it looks like you have 3 feet - does that provide enough stability for the table? thanks
REY
« Reply #2 on: 9 May 2020, 01:23 am »
Deck is exactly the same dimensions as a regular Rega table, they come with 3 feet from the factory, I think Nagaoka is hard to be under the $350 range, I have also a Vessel A3SE that does not have any right to sound the way it does for $99.
denverartist
« Reply #3 on: 13 Oct 2021, 10:37 pm »
Did this custom Rega Turntable ever sell?
I'd sure be interested ...
-Pete
