Benchmark AHB2 amplifier - single amp versus 2 mono amps
0 Members and 1 Guest are viewing this topic. Read 1243 times.
soundhound
I have read a number of reviews and opinions regarding the Benchmark AHB2 amp.  A number of users and reviewers have given this amp excellent reviews for its transparency, but some have found it sterile.  Interestingly a few reviewers including reviewers for both Stereophile and the Absolute Sound have found the AHB2 to work well with many speakers.  However with a few other speakers- both electrostatic and dynamic, the same reviewers have noted that a single AHB2 did not work as well producing a cool or sterile sound; the AHB2 was not noted to be clipping.  Neither reviewer had an explanation for these suboptimal interactions.  While Benchmark states that using 2 mono'ed amps does provide greater voltage swings but not change the tonal characteristics of the amp, other users have suggested that 2 mono'ed amps do improve this cool tonal balance seen with the single amp.  Have others seen such an improvement with 2 mono'ed AHB2 amps and does anyone have a technical explanation for this observation?
Re: Benchmark AHB2 amplifier - single amp versus 2 mono amps
« Reply #1 on: 28 Apr 2020, 05:04 pm »
Welcome  :thumb:
Wind Chaser
« Reply #2 on: 28 Apr 2020, 06:27 pm »
I don’t think you’re going to come to any objective conclusion on this because so much is predicated on various opinions, preferences and agendas. Having said that I’d be curious to see if this amp lives up to its hype.
soundhound
« Reply #3 on: 28 Apr 2020, 08:25 pm »
I suspect that Wind Chaser may be correct regarding the differences of experiences with the AHB2.  I was initially quite impressed with many of the reviews of the AHB2 as well as the remarkable testing results.  In addition, I spoke with individuals knowledgable about Martin Logan speakers including some at Martin Logan who had excellent results using the AHB2 with hybrid Martin Logans.  I have Martin Logan CLX's which obviously are nearly full range electrostatics  and have a difficult impedance curve.
In my system I have used a number of well regarded amplifiers over the years with these speakers including Pass Labs XA100.5 monoblocks, a Krell 402e, and an Audio Research Ref 150 to power the CLX's.  I am currently using a recently manufactured Coda 15.5 which remains in Class A up to 100 watts and then transitions into AB up to 150 watts but is stable down to at least 2 ohms.  The Coda 15.5 drives the Martin Logan CLX's reasonably well and in my imperfect audio memory better than its predecessors.  Being the curious audiophile that I am, I purchased a single AHB2.  The upside is that it does have high signal to noise and outstanding transparency with the CLX's.  The downside was its lack of harmonic density and a lack of mid to upper bass dynamics which may be due to the capacitive character of the impedance of these speakers. As I mentioned previously, seasoned audio reviewers noted similar findings in using the AHB2 with Monitor Audio speakers and Muraudio electrostatics. I would add  that these changes were apparent without clipping.   While personal preferences in audio and differences in systems may account for differences in subjective responses, I am curious if the more technically knowledgeable members might have some thoughts on the technical basis
of such  AHB2/speaker interactions and whether the extra voltage provided by using 2 mono'ed AHB2 might remedy these suboptimal responses.
jdoyle
« Reply #4 on: 28 Apr 2020, 09:13 pm »
Welcome!
I’m very happy with my Benchmark DAC3 and ABH2 amp, but I’ll be the first to say that I didn’t really compare it to much.
You might be interested though with one of the reviews posted on Benchmark’s website that mentions your very inquiry.
Benchmark recommended going with their New Line Amp in place of adding a second amp.
I’ll paste the review:
AMAZING
BR on Aug 13, 2019
Very happy owner of a benchmark dac3l and AHB2 . Was considering a second ahb2 to drive my Martin Logan Ethos but having spoken to Benchmark they advised I'd probably get more value out of an la4. How much difference can a volume control make ? A truly unbelievable amount it seems . The amount of previously unheard detail is something else . That and rock solid imaging at any volume level - the sonic signature remains the same at any level . The sonic ceiling has been blown off ! Any ahb2 dac3 owners sitting on the fence - don't - you will be very happy ..it's almost baffling how much it improves an all benchmark system .
JD
Phil A
« Reply #5 on: 28 Apr 2020, 11:27 pm »
Welcome!
soundhound
« Reply #6 on: 29 Apr 2020, 05:26 pm »
I should have noted that I have a Benchmark LA4 Line Stage which I used in conjunction with the AHB2 amp as well as with the Coda 15.5.  I agree that the LA4 is an excellent preamp which works well with both the Benchmark AHB2 and other amplifiers.  The somewhat cool tonal balance I perceived with the AHB2 was apparent with the LA4 but not when the LA4 was used with the Coda 15.5.
