Larger Sub in kit form?
0 Members and 1 Guest are viewing this topic. Read 2538 times.
dcox
« on: 20 Feb 2005, 07:08 pm »
Can I purchase a Larger sub in kit form?
I'd like to get a price both with and without the cabinet.
I would definitely want Megawoofer option.
Thanks...
David
John Casler
Re: Larger Sub in kit form?
« Reply #1 on: 20 Feb 2005, 07:43 pm »
Quote from: dcox
Thanks...
David
Hi David,
The LARGER sub kit (according to my sheets) is $579 w/cabinet
and $329 wo/cabinet
Megawoofs are $140 additional and SoundCoat is $75.
Additionally you can now add Piano Black finish $40 and a 1000watt amp for $399.
Other options include: Passive x-over $35 kit/ $45 assem, Analysis Plus Silver wiring $200,
The above are retail list prices, and might be slightly lower through "courtesy pricing" through your dealer.
Although dealers do not offer the same courtesy % off kits as they do assembled, and I have found that it is best to purchase kits through Brian directly, since most dealers are not able to answer detailed construction/assembly questions on kit building, unless they have built them, themselves. (of course there are exceptions, but I'm not one :lol: )
Brian can clarify, if my info is outdated.
rosconey
« Reply #2 on: 20 Feb 2005, 07:55 pm »
the kit is a heck of a value -thats how i bought mine
if your in the nyc area a ac member has one for sale.
grub
« Reply #3 on: 20 Feb 2005, 10:56 pm »
What's involved in completing a kit with cabinet (without a passive xo)?  Simply putting the woofs in the holes, a little extra speaker wire, and a few crimped connections?
If that's it, it doesn't seem too hard to put one together.
-->grub
Florian
« Reply #4 on: 21 Feb 2005, 02:35 am »
Hehehe, i have a feeling it takes a little more than that  :lol:
Not that i know, but usually if i think something is easy it brakes my back. But it would be cool to build your own.
YoungDave
assembly of larger sub kit
« Reply #5 on: 21 Feb 2005, 04:38 am »
Well, actually, that is just about it.  I had a morning's pleasantry assembling mine a year or so ago.  Strictly no sweat.
About the only thing I would add to your surmise of the assembly process is:
1.  No crimps - always solder with good silver-bearing solder.
2.  You also have to screw the "foot" onto the cabinet.  So, a few screws for the speakers, a few for the foot, solder a little wire, and that's it.  Then setup & play.
Cheers
J
« Reply #6 on: 21 Feb 2005, 05:19 am »
Quote from: John Casler
Hi David,
what brand of amp?
I put a orig together in 86 and another around 90, great subs!
J
« Reply #7 on: 21 Feb 2005, 05:41 am »
Quote from: J
Hi David,
what brand of amp?
oops ,did not see the sticky
grub
« Reply #8 on: 23 Feb 2005, 05:46 am »
YD,
Are the holes pre-drilled?  That sounds like a do-able kit to me.
-->grub
covermye
« Reply #9 on: 24 Feb 2005, 07:21 pm »
Holes are pre-drilled.  In the case of the subs, at least, the kit savings is well worth the tiny bit of simple assembly involved, IMO.  Go for it, as long as you've got a big soldering gun.
I found the heavy wire for the subs too much for my 30W Radio Shack pencil and borrowed a friend's 50W/100W 2 stage gun.  If you use a bigger gun like this, be careful that you don't apply TOO MUCH heat and damage the spades...
grub
« Reply #10 on: 24 Feb 2005, 09:21 pm »
Thanks for the info....this sub kit sounds highly do-able.  When I muster up the bread for one, I'll go for it in kit form.
-->grub
