SOLD - Dynaudio Excite x34 Speakers
0 Members and 1 Guest are viewing this topic. Read 908 times.
apstoltz
« on: 25 Apr 2020, 09:19 pm »
Up for sale are my beloved dynaudio excite x34 floorstanding Speakers. They are in great shape with the exception as I do not have the grills, they cover up their beauty anyway. I would rate these 8/10.
I am looking for local pickup in Indiana.
The slimline Excite X34 stands less than 95 cm tall and is only 17 cm wide, but its dual MSP mid/woofers, coated soft dome tweeter and special dispersion character serve up unmistakably high-end sound.
With its extremely lightweight aluminium voice coils and greater driver membrane radiating area and larger enclosure volume than a compact speaker, it can produce deep, powerful bass even in spacious rooms from its twin 14cm long-throw MSP mid-bass drivers and 28mm tweeter. Precise fine-tuning of the crossover optimises dispersion for incredibly an accurate, three-dimensional presentation of the recording. Just as the artist intended. The X34 is also extremely amplifier-friendly due to its ultra-linear 8 Ohm impedance.
The exquisitely finished cabinet includes a cloth grille secured by concealed magnets, and has a smart base construction: on hardwood floors, the X34 can stand on four resonance-absorbing feet, while four adjustable integrated spikes may be used to achieve a perfect foundation on carpeted surfaces.
Technical specifications
Wilfried Ehrenholz, Founder, Dynaudio
Specification sheet for Excite part 2
Sensitivity:
86dB (2,83 V /1m)
IEC Power Handling:
200W
Impedance:
8 Ohms
Frequency Response (±3dB):
37Hz – 23kHz
Box Principle:
Bass Reflex Rear Ported
Crossover:
2 1/2 way
Crossover Frequency:
1800Hz
Crossover Topology:
1st/2nd order
Specification sheet for Excite part 1
Woofer:
2 x 14cm MSP
Tweeter:
28mm soft dome
Weight:
17kg / 37lb
Dimensions (W x H x D):
170 x 900 x 260mm
6.7 x 35.4 x 10.2in
Dimensions with feet/grill (W x H x D):
228 x 928 x 281mm
9 x 36.5 x 11.1in
Local Pickup in Indianapolis, In
Price- $1040
« Last Edit: 5 Jul 2020, 09:23 pm by apstoltz »
apstoltz
Re: FS: Dynaudio Excite x34 Speakers
« Reply #1 on: 6 May 2020, 12:20 pm »
I am willing to meet 2 hours away to accommodate a purchase. Great set of speakers looking for a good home.
apstoltz
« Reply #2 on: 4 Jun 2020, 09:00 pm »
Price Reduction - great speakers that need a new home.
