0 Members and 1 Guest are viewing this topic. Read 2215 times.
By "adapter" I don't mean a cable, but these: https://www.amazon.com.au/Hosa-GPR-101-Adaptors-pieces-Black/dp/B000068O3S(You can find nicer metal ones)
So I want to order some IC's from the pre-amp's RCA into JBL powered monitors. My choice is either the 1/4" TS connector or the XLR. Any preference or sound difference?
Hey! Technically XLR is best but only if your source or preamp also have XLR output. Buddy
Lots of talk about 3 pin and connections that I don’t understand but are the Moon adapters OK with the Bryston inputs.
