Technical notes on our planar midrange
0 Members and 1 Guest are viewing this topic. Read 2154 times.
Brian Cheney
    • http://www.vmpsaudio.com
« on: 19 Feb 2005, 09:02 pm »
There has been some discussion about our mid panel on other AC forums, and I have more details from the designer for Sonigistix, Dragslav Colich, on the panel's performance parameters.
As pointed out elsewhere, the Level 9/Sonigistix panel was in production for about 4 years and over 300,000 units were manufactured.  Most went into computers, Kia automobiles, and high-end multiway speaker systems of which the VMPS RM series are the best known.  The panel has a low Fs (below 200Hz), high sensitivity, high output levels, excellent power handling and durablility, and very low moving mass (less than 1g per panel).
Just how much linear travel this panel exhibits has been subject of some discussion.  When I inquired about "Xmax" Level 9 gave me the figure of 3.5 mm.  However, there are more considerations that linear travel in the middle of the diaphragm.  As the magnetic gap increases, so does maximum linear travel, but (as in cone dynamic speakers) efficiency suffers.  In addition, high excursions weaken the tension of the diaphragm and will cause it to flatten, curl and loosen up, resulting in  high THD when driven hard.  Plus, high excursions mean high flexure rates and fatigue of the aluminum traces which can also lead to failures.
Our panel has a rear damping sheet (none on the front, unlike the BG Neo 8 where the diaphragm is sandwiched between two damping sheets and has little to no free travel).  Given the presence of the damper and the thickness of the diaphragm the peak to peak displacement for maximum SPL is about 1.3mm.  Within these parameters diaphragm excursion is linear and uncompressed down to the resonant frequency.  Multiplying the number of drivers in an array increases output and even gives the designer the option of lowering the crossover point.
Dragslav relates that many different arrays were built with our drivers early on with excellent results.  For example, one array of 192 (!) panels allowed a dipole to generate 105dB SPL at 2m down to 80Hz, more than an octave below fundamental panel resonance.
Our measurements of the frequency response of the panel show linearity typically +/- 2.5dB, Fs of 166Hz and THD below 1% right down to cutoff, which is typical of high quality cone dynamic drivers.  Since the panel is almost 3" wide we roll it off at 6dB/oct with a series lowpass filter at 6.9kHz in order to improve HF directivity.
Buzzing, loss of diaphragm tension, and thermal overload are the typical failure modes of planar LF drivers.  As is clear from the above, the panel's design is a careful balance of sensitivity, maximum linear excursion, THD, LF cutoff, and distortion.  Our panel has proven to be a good performer of outstanding sound quality and reliability (less than 1% total failure rate from all causes.) Currently we use 12 dB (from series first order networks) highpass filters in the 280-300Hz range, after first engineering some new WCF cone woofers better suited for use with our mid panels.
I'll be happy to relay further questions you might have to Dragoslav, who dislikes participating in on-line discussions due to their volatility and open-ended nature.
warnerwh
« Reply #1 on: 20 Feb 2005, 03:24 am »
Thank you for the information. It appears you have moved the crossover up even higher from the midbass to the midrange.  Nobody who has heard the quality of the midrange of these panels have much doubt about the incredible quality of sound.  I know one person who is very much looking forward to getting a new pair of RM 40's.
ekovalsky
« Reply #2 on: 20 Feb 2005, 08:32 am »
Thanks much for the information!
Based on my in-room measurements and listening impressions, 250-300hz seems to be the sweet spot for the woofer to planar transition.   Luckily the 10" WCF woofer in the RM/X seems very capable of performing with a 24dB/octave slope at 275hz.
Any update on "Direct Drive" models ?   I'd like to see the RM30, RM40, RMX offered with three pairs of binding posts (connecting directly to the woofers and planars and with a protective cap in series with the tweeter) and deletion of the L-pads.  An optional passive crossover box with mid and treble L-pads could be offered for use with conventional systems.
buffer
Any changes to Active Crossover...?
« Reply #3 on: 24 Feb 2005, 12:38 am »
Brian,
Regarding the following statement:
Does this apply to the FF1SRE w/Active Crossover?  As I recall, the Active Xover is24db/octave.  I often  wondered the system would sound like if I transitioned to the mids at a higher frequency ...250Hz for example.
Also, and I never asked...
With the change from the old BG ribbon to the newer mids, did you have a new suggested Frequency selection for the Active Crossover?
Have you changed the active crossover, or added a higher frequency cutoff point  since I purchased mine (which has a cutoff of about 190Hz)?
