0 Members and 1 Guest are viewing this topic. Read 4526 times.
I thought the EX had an optical input alreadyIt's listed as having one on the Sharp website
How does the modded one sound compared to the stock?
Hi Vinnie.First, good luck with your new venture!Second, do you think there is any means of adding a digital input (either optical or coax or even USB) to this unit? I was really tempted to get one of these as a bedroom system, but want to be able to connect it to my computer in some fashion.Thanks!
You have read my mind Vinnie! But the one modd that I am mostly interested on it to be able to use the Sharp as a full digital amplifier and running the section directly via the Aux inputs with my choice of amplifiers. How difficult or expensive would be a mod like this. Furthermore, there must be a way of adding a toggle switch to be able to use the unit back with all its functions. Would there be degradation to the sound if the amplifier had a variable gain via its own volume control and then, run with gain via an outside preamp? What is the best or most appropriate way? PS: These units are really, really selling like hotcakes. I think I might order myself a second one just for fun. Paul
Hi,My Sharp sd-ex111 died in it's first hour of operation. No response anymore except for a clicking sound when attempting to turn the unit on. Resetting does not work either. Can anybody provide me with some insight? Is there hope for the little machine or should I send it back to overstock?Thanks!
Adding a digital input will require a spdif receiver and dac chip. Probably the easiest (and less expensive) way to do this is to have a dac board like the Scott Nixon DacKit installed (which is a nice non-oversampling digital filterless design at a very good price BTW). This could be fed from one of the 12V lines, and then a coaxial jack could be installed.
Hi Vinnie - Thanks for the response!I don't know the details of how a S/PDIF receiver works, but do you really need the DAC? Converting the signal to analog seems to defeat one of the primary advantages of the 1-bit technology - keeping the entire audio chain digital until output from the amps. So to keep the stream digitial, it appears that you need the chip that converts S/PDIF to PCM, and then PCM to the 1 bit data stream. Of course, I'm guessing that you can't just pick them up at Radio Shack!
Vinnie,This may be an apple and oranges question, but how does the modded Sharp sound compared to the Clari-T?
Quote from: JLMVinnie,This may be an apple and oranges question, but how does the modded Sharp sound compared to the Clari-T?Vinnie, Can you please share your opinion on this question?Thanks
Thanks Vinnie! You will be hearing from me pretty soon about extra sets of RCAs and the toggle switch. More than anything, I would like hear what digital amplification sounds like with my First Sound Paramount Hotrod which amplifies the signal directly through a pair of 6922 tubes. The best of both worlds, super tube and simple, well made digital. Paul from NYC
