MC Advise
0 Members and 1 Guest are viewing this topic. Read 862 times.
deuter
MC Advise
« on: 18 Apr 2020, 09:28 pm »
I'am looking to get a low output cartridge and need your advise and recommendations on which ones to research.
The Price Range is $2000-$4000.
The Sound I'am after is excellent detail retrieval (match digital) with pin point and spatial imaging and most important of all Huge Bass (sub bass slam and low extension)
I know its a hard question as most will recommend one or the other as audiophile we don't necessary keep swapping cartridges, but may be you are an audio dealer - Ideally you would be selling 20-50 cartridges and a few in my price range. Based on my Sound Characteristics you might be able to say Cartridge A is $2500 and surpassed Cartridge B at $4500 in the area of detail retrieval but not with Sound stage.
That's sort of what I'am hoping to achieve from this exercise, some in depth advise.
As with everyone I would like to keep the spend low but really go to the upper extreme its definitely worth it compared to the offerings at the opposite end.
jsm71
Re: MC Advise
« Reply #1 on: 19 Apr 2020, 01:03 pm »
A bit more info might help others narrow their recommendations.  When you say "low output cartridge" does this imply simply a MC cart (regardless of its output), or are you specifically looking for a lower output MC cart?  Output varies widely across the full range of MC carts.
Also, what phono stage/preamp are you using?
Lastly, what prior experience with MC carts if any do you have?
deuter
Re: MC Advise
« Reply #2 on: 19 Apr 2020, 09:04 pm »
Very low output is what Iam after.
I have the Parasound JC3 phono
I have used the Dynavector 17D3 and the DV-XX2 prior.
deuter
Re: MC Advise
« Reply #3 on: 27 Apr 2020, 10:20 am »
An update on what I purchased, a Lyra Kleos SL.
So far its very detailed with a balanced sound across all frequencies.
