Entry Level Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 1889 times.
Audio Nutt
« on: 19 Feb 2005, 03:27 am »
I'm looking to buy an entry level phono preamp and would like to keep the price tag below $200.  A guy at work strongly recommended the "Bellari VP129" that supposedly can be had for about $125.  I've been around audio for a number of years, but to be perfectly honest I've never heard of this brand.  Any thoughts would be appreciated.
Thanks.........Audio Nutt
doug s.
  • makin' music
Re: Entry Level Phono Preamp
« Reply #1 on: 19 Feb 2005, 08:16 pm »
Quote from: Audio Nutt
here's a shameless plug!   :wink:
http://cgi.audiogon.com/cgi-bin/cl.pl?preaphon&1113776919&item
make me a reasonable offer - this really is a decent fono stage; it works great w/my low-output ortofon mc25-fl moving coil...
doug s.
doorman
entry level phone stage
« Reply #2 on: 19 Feb 2005, 10:44 pm »
You might check out the Hagerman "Bugle" battery or ac powered, can be configured for 40,50, or 60db of gain. www.hagtech.com cheers, D
hmen
« Reply #3 on: 20 Feb 2005, 12:53 am »
I was just looking at the Bellari's specs   http://www.rolls.com/ and it only gives you 30 db gain. Kinda weak.
