Vincent Audio SP-997 Mono Blocks $625
0 Members and 1 Guest are viewing this topic. Read 1563 times.
that1guyinwi
  • Just a Audio hobbyist
« on: 14 Apr 2020, 12:47 am »
Selling a pair of Vincent Audio Mono Block SP-997. Excellent condition. Upgraded to Tube Intergraded. Non smoker home.
Also includes a pair or Pangea AC-14SE power cables.
$625 plus shipping. From Wisconsin zip 54729
Here are the specs-
Fully balanced mono poweramplifier. Although the construction is compact, the amplifier has sufficient power. Combined with the KHV-1, it is used on places with limited space.
Through the 12V trigger connections the amplifier is also optimally suitable for Home Cinema use.
Technical Specifications
Frequency response: 20 Hz - 50 kHz +/- 0.5 dB
Nominal Output Power RMS / 8 Ohm: 150 Watt
Nominal Output Power RMS / 4 Ohm: 250 Watt
Harmonic Distortion: < 0.1 % (1 kHz, 1 Watt)
Input Sensitivity: 1.2 V
Signal-Noise Ratio: > 95 dB
Input Impedance: 47 kOhm
Max. Power Consumption: 263 Watt
Inputs: 1 x Mono RCA, 1 x Mono XLR, 1 x 3.5 mm Jack (Power Control)
Outputs: 1 x 2 Speaker Terminal, 1 x 3.5 mm Jack (Power Control)
Colour: Black / Silver,
Weight: 6,5 kg,
Dimensions (WxHxD): 160 x 268 x 225 mm
« Last Edit: 19 Apr 2020, 12:10 am by that1guyinwi »
