0 Members and 1 Guest are viewing this topic. Read 6978 times.
Since the panel at the right side of your photo appeared to be 4" deep, I searched the linked web site, but found only 2" products. Also, I didn't find any lab tests on the site.
When I see the cost of very low frequency effective corner traps (e.g., Real Traps, others like that), it's insane...esp. times four corners, to 6 or 8 feet high...like $900 per corner.
Hi Mick. Thanks for your input. No, you're not off base. All feedback is welcome! But what made you think my system wasn't already set up in the room? I've kinda settled on the system location (for now?) My current setup is where I came to after much experimentation, much advice, and a final recommendation from an acoustic engineer. Doesn't mean I won't experiment some more, though.I'm not quite sure what to make of the last couple sentences, RE: speakers and room overload, "in this case." I must be missing something.
