SOLD - SoTM tX-USBultra (maxed out with 3 sCLK-Ex tap) and tX-USBexp
0 Members and 1 Guest are viewing this topic. Read 541 times.
shahed
Selling SoTM tx-USBultra and tx-USBexp as package deal. Both in excellent condition.
tx-USBultra is maxed out with all possible options:
- 9V power (easily switchable to 12V with jumper settings)
- Evox caps upgrade
- 50 ohm master clock input
- eABS-200 EMI shielding
- 7N UPOCC copper wire upgrade
- Additional 3 SCLK-EX clock tabs output in the back. 24M/25M/48M. (24M input can be fed to a NUC usb controller and 25M can replace the clock of a network controller)
Original cost: $1650.
tX-USBexp:
- Upgraded to have the 48M clock feed from tx-USBultra.
- tx-USBexp is a very good USB PCIE card on its own regard. After having its signal fed from sCLK-EX 48M from the tx-USBultra, the improvement in sound was profound.
- If you have a master clock or plan to get one in future (SoTM OCX10/Mutec Ref/Cybershaft), you can feed it to the tx-USBultra and it will take your tx-USBexp sound quality to next level.
- If you plan to use 24M/25M clock output to feed an endpoint usb controller/LAN controller, using master clock you can have significant performance improvement in future.
Original cost: $400.
The clock cable to connect from the Ultra to the tx-USBexp comes for free. I've a Lush 2 USB cable that will sell for a good price, if you are buying this combo.
Selling the Ultra and USBexp PCIE card together. Asking $1120. Buyers pay shipping from 10002 and add 3% for paypal (if not using friends/family option).
« Last Edit: 17 Apr 2020, 06:18 pm by shahed »
