Series and Parallel
0 Members and 1 Guest are viewing this topic. Read 4725 times.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: Series and Parallel
« Reply #40 on: 11 Apr 2020, 04:52 pm »
Changing the impedance of the bass drivers means a change in XO (level issues as well). But an even number of drivers is easier to get to a usable ipedance.
You either wire each box in series and parallel the 2 boxes, or wire the drivers in parallel, and then wire the 2 boxes in series. Which is best depends on amp and the impedance of an individual speaker.
dave
Housteau
« Reply #41 on: 11 Apr 2020, 05:18 pm »
dave
If starting from scratch then yes, this is logical.  But, this was an added option and not designed in from the beginning.
ZAKski288
« Reply #42 on: 11 Apr 2020, 06:48 pm »
Hello Dave ,  doesn’t the Xilica 4080 have 8 outputs, so you would not have to series the two bass modules together, just add a couple more amps.  More power.   Ken
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #43 on: 11 Apr 2020, 06:52 pm »
Dave, me? What is a Xilica 4080 or have i missed something?
dave
ZAKski288
« Reply #44 on: 11 Apr 2020, 06:56 pm »
No, Mr. Housteau’s first name is also Dave, Sorry for the confusion. Ken
Housteau
« Reply #45 on: 11 Apr 2020, 07:11 pm »
Yes, it sure does and I could.   But, I see no reason to bring in another set of amps.  The frequency range covered by these units is very narrow and an 8 ohm load with both in series would be a normal load.  I am using a set of Odyssey Stratos Extreme Mono SE's there now and I am sure they are feeling very underutilized.
Housteau
« Reply #46 on: 11 Apr 2020, 07:24 pm »
Only problem with this solution is the two in series would get collectively half the power going through the series parallel system because they would represent a 12.6Ω load. So, each of those drivers would handle 1/4 the power that the single parallelled 6.3Ω driver would handle.
Since it is V shaped, the two in series appear to be on each side, with the one in parallel facing forward.   This must be the design intent.  The upper section is a full dipole, actually as a rear facing horn with the folded back wings.
« Reply #47 on: 11 Apr 2020, 08:13 pm »
STM try adjust two loudspeakers with 3 woofers each its a mod too expensive with uncertain sound results since a superb Neo 15'' Eminence woofer cost just only $220 each and Ferrite models even cheaper.
https://www.eminence.com/speakers/speaker-detail/?model=Kappalite_3015
« Last Edit: 11 Apr 2020, 10:41 pm by FullRangeMan »
