Project carbon rpm 3 with upgrades and power supply
0 Members and 1 Guest are viewing this topic. Read 529 times.
Ryan0348
Project carbon rpm 3 turntable with denon dl103r cart. Has upgraded acryl-it platter. Also come with a project uni power linear supply which puts out 20v but i have a drok voltage regulator that is adustable in .1v increments to adjust the voltage down to 15volts. Using the drok regulator also allows you to set the rpm of the table to exactly 45 or 33.3 by adjusting the voltage in .1 increments. Project sells a little stand alone voltage regulating box that does the same thing.
1000$obo
