4 ohm or 8 ohm setting for Supercharged Songtowers?
0 Members and 1 Guest are viewing this topic. Read 1023 times.
TKonrad.NOLA
Just got a new tube Amp.   SCST says 4 ohm design, 6 ohms nominal.  Am I wrong in assuming I should use the 4 ohm setting?  Thanks in advance.
opnly bafld
Re: 4 ohm or 8 ohm setting for Supercharged Songtowers?
« Reply #1 on: 3 Apr 2020, 03:32 pm »
No harm in trying both.
TKonrad.NOLA
« Reply #2 on: 3 Apr 2020, 03:39 pm »
Good point
Hydro
« Reply #3 on: 3 Apr 2020, 03:42 pm »
See which one sounds better. The main thing with a tube amp is to always have a load hooked up to it when it is on. Some amps are very sensitive to this and could blow tubes or components. Turn the amp off when changing from 4 to 8 ohm taps. Solid state amps are just the opposite and can take no load when turned on.
mick wolfe
« Reply #4 on: 3 Apr 2020, 05:02 pm »
Yep, that's exactly what I did over the years with my original Songtowers. In my case, I ended up leaving it on the 8 ohm tap. This may vary depending on the amp used, but let your ear decide.
