True Flac
0 Members and 1 Guest are viewing this topic. Read 925 times.
dflee
True Flac
« on: 2 Apr 2020, 03:17 pm »
I listen to a web site called Radio Paradise which has a Flac setting.
I listen through a dac/amp (Liberty) off the laptop.
Am I getting actual flac?
Don
dB Cooper
Re: True Flac
« Reply #1 on: 2 Apr 2020, 03:21 pm »
If you are, I want to know about it'
Update after visit: It look like it. Seems to be essentially an 'eclectic rock' outlet, with most of the stuff that shows on their tracklist being familiar stuff.
richidoo
Re: True Flac
« Reply #2 on: 2 Apr 2020, 03:30 pm »
Yes.
Your browser decodes the FLAC compression and sends the WAV to your DAC.
dflee
Re: True Flac
« Reply #3 on: 2 Apr 2020, 03:41 pm »
Thanks guys.
Is there a classical web site that does the same?
Is there a list somewhere that tell you who has flac?
Don
yeldarb
Re: True Flac
« Reply #4 on: 3 Apr 2020, 01:21 am »
Listening to it on my modded Fostex phones right now.  I have listened to RP for years, when I can.  The FLAC stream is more reliable than their MP3 streams were and sounds as good as most CDs.  If you like their stream,donate to keep them going.   :D
