0 Members and 1 Guest are viewing this topic. Read 7075 times.
Update: I’ve now placed these on stands with a toe in angle around 15 degrees. This position change has bumped up imaging & the soundstage notably (in a 3D/holographic manner). The low end is tighter & more pronounced. I’m willing to walk back my previous observations/statements regarding the playback of hip hop & rock, EDM genres through continued listening post these speaker placement changes.
Full range: He likely means the speakers are not high passed (with a sub for bass).
Hmmm...am I playing these full range? I’m not sure that I follow? Yes these are full range drivers (if that’s the question). There’s a crossover employed in the design between the (2) speakers to manage high/low frequencies. I can say the dynamics are superb (detailed & transparent...source dependent of course). The most significant difference, from the Spendor A1 monitors that I’d grown accustomed to, would be the transparency followed by warmth. The HO’s are less forgiving to my ears...they tell it like it is...comparatively speaking....& they are ‘less’ warm IMHO. These aren’t cons; just tonal or tuning design differences. Full disclosure...I was eyeballing the BBC monitor sound when I purchased the HO’s. My selection to purchase the HO’s was based largely on the efficiency; to (speaker) match my upstream gear/chain (MZ3 & Aegir). I’ll likely cycle a pair of Graham Audio Chartwell LS3/5 monitos or Harberh P3ESR monitors to solely satisfy my curiosity. But honestly...I have no merit worthy qualms against the HO’s. These are solid in both build & sound signature...holding their own with the likes of custom Salk Silk Monitors...which I’ve also owned...albeit in an entirely different use-case set up.
Realize they need lots of hours to break in. The best is ahead of you.
I would argue that proper placement and system building should obviate the need for equalization or DSP.
