Integrating DSP with DAC10
0 Members and 1 Guest are viewing this topic. Read 1349 times.
What Me
« on: 29 Mar 2020, 12:35 am »
Hi,
I'm currently running two subs and would like to ensure the integration is as good as it can be with the mains and the room.
Just wondering if anyone is running a DSP with the DAC10 and if so what is the implementation and how does it sound?
Kev
in1unison
Re: Integrating DSP with DAC10
« Reply #1 on: 12 Apr 2020, 04:44 pm »
Hi Kev,
I am running miniDSP DDRC-24 between DAC-10 and ST-10M, driving Magnepan 1.7i and two B&W subs. DDRC-24 runs Dirac Live 2.0 room correction algorithm. Very flexible, tunable solution and it sounds great. MiniDSP dot com will give you details as to the possible set ups.
Best regards,
Jan A.
