Anyone upgrade their Coincident Line stage Volume Pots?
0 Members and 1 Guest are viewing this topic. Read 1939 times.
RPFMusicman
I have a Coincident Tube Line Stage which sounds great. I'd like to upgrade the volume pots. If anyone has had this done I'd appreciate a response.
RPF
« Last Edit: 28 Mar 2020, 06:35 pm by RPFMusicman »
Re: Anyone upgrade their Coincident Line stage Volume Pots?
« Reply #1 on: 31 Mar 2020, 07:26 am »
RPF
What pot type and value you have now?
Scroof Neachy
  • I like to smell stuff
« Reply #2 on: 14 Apr 2020, 12:59 am »
What’s wrong with the volume pot that came with it?
« Reply #3 on: 14 Apr 2020, 01:03 am »
 :lol:  8) :thumb:
richidoo
« Reply #4 on: 14 Apr 2020, 01:26 am »
A stepped attenuator with quality resistors almost always sounds better than a potentiometer.
Gold Point is among the best, if you don't need remote control.
Intact Audio autoformer attenuators are possibly even better.
Alps makes good pots, but that's probably what you have. TKD pots are excellent, but honestly I don't know how they compare to Alps' best.
Various quality pots from good British seller.
« Reply #5 on: 14 Apr 2020, 01:34 am »
Well, there is the Khozmo at realistic prices:
https://khozmo.com/products_dale_shunt.html
RPFMusicman
« Reply #6 on: 19 Nov 2020, 09:59 pm »
thank you for the responses. Spoke w/ Israel at Coincident and he thinks one of the volume controls are faulty. I'd like to get them both replaced and working properly. I do enjoy the sound of this preamp.
sfox7076
« Reply #7 on: 20 Nov 2020, 02:59 am »
Good luck.  Slagle's autoformers crush the competition hands down.
glynnw
  • I have tin ears.
« Reply #8 on: 20 Nov 2020, 06:28 am »
And circle sponsor Tortuga Audio just introduced a version of their LDR volume control that is specifically made to replace existing controls.  Not cheap, but highest sound quality.
jmolsberg
« Reply #9 on: 20 Nov 2020, 12:58 pm »
Following a suggestion form Rollo, I recently swapped my pots with TDK 2500 and they are most excellent!
Michael Percy sells them
RPFMusicman
« Reply #10 on: 20 Nov 2020, 07:45 pm »
thanks for the responses. I'll look into the TDK!
RPFMusicman
« Reply #11 on: 20 Nov 2020, 07:50 pm »
jmolsberg, do you have a link to the TDK or a contact email?
thank you,
RPF
