0 Members and 1 Guest are viewing this topic. Read 3048 times.
These mono amps are supposed to be twins, but the caps on what seems to be the power regulation board don't match up from amp to amp. It does seem symmetrical between the positive and negative rails in each amp, but the caps in the first amp (pair of 47 uF 100V) are different from the pair in the second amp (100 uF 63V).When replacing the caps, do I replace them exactly as I find them, or do I make each amp the same?If I go for uniformity, which amp sets the standard?
The AC power input has an RFI/EMI filter module. Do those go bad/get used up over time?
I've noticed a few more differences. There is what seems to be a fine tuning resistor that is attached between posts that looks different between amps. 47.5kΩ 1% vs.metal film resistor B(or 8)252FJand the some of the trimmers are yellow vs. blue, along with a few other resistor differences. Could those trimmers still be adjusted after being painted so heavily?I wonder if someone repaired these. I recall something about the warranty being void if the amps were used with certain tube pre-amps that were destabilizing and resulting in failure. Or maybe I'm just seeing a part selection/availability difference over time.
I've got to say, this thread makes me miss Dan Banquer. Not buying one of his amps was a big regret for me; I think they were very 'special' and I would like to have had something to remember him by. He was real 'old school' and this amp is testimony to 'doing it right, by the book', and good design over fancy componetry.
His advice about the tube preamps was to prevent DC being applied to the amp's input. Many tube preamps that lack output relay will make DC until they warm up. Many people can't wait that long. Dan allowed only AudioResearch tube preamps because (apparently) they all had output relay on timer. He was right in that there was a lot of amateur designed tube junk being sold back in those days. I guess the LPNA-150 does not have input caps?
How to you like the sound so far? It will change as the caps burn in.
