BCD-3 display brightness
0 Members and 1 Guest are viewing this topic. Read 1342 times.
WillyP
« on: 24 Mar 2020, 10:30 pm »
Hi James,
My BCD-3 CD player does a wonderful job, but the display brightness is a little bit too much for these old eyes. Is it possible to dim the brightness with a code of the BR2 remote? I know, it can be done with a web browser, but my BCD-3 is not connected to a network, unfortunately.
Many thanks in advance,
WillyP
CanadianMaestro
Re: BCD-3 display brightness
« Reply #1 on: 24 Mar 2020, 11:54 pm »
I switch my display off completely (BCD-1), using BR2.
cheers
WillyP
« Reply #2 on: 25 Mar 2020, 12:25 pm »
Thanks, CanadianMaestro, for your reply. The procedure for the BCD-3 is the same as for the BCD-1 and it works. It is an all-or-nothing solution, though. I ’d rather see what is going on on the display, only not so bright.
Kind regards,
WillyP
« Last Edit: 25 Mar 2020, 02:58 pm by WillyP »
CanadianMaestro
« Reply #3 on: 25 Mar 2020, 01:30 pm »
Good to know, Willy.
On BCD-1, the display is tiny, so I can't see anything from my chair.
It's unlikely, imho, that the display brightness can be fine-tuned.
My preamp has it (LS27), but ARC says that needs a bit of electrical working to do it.
Enjoy the musik,stay healthy.
cheers
sweetspot
« Reply #4 on: 25 Mar 2020, 05:15 pm »
There was 3 brightness settings plus off for the bcd-1.Don't know why they didn't do the same for the bcd-3.
CanadianMaestro
« Reply #5 on: 25 Mar 2020, 05:35 pm »
How do the BCD-1's three brightness settings progrmed on the remote? The manual says only on/off:
https://www.manualslib.com/manual/795139/Bryston-Bcd-1.html?page=6#manual
WillyP
« Reply #6 on: 25 Mar 2020, 05:56 pm »
Just a little update,using my BCD-1 remote to control the BP-26 vol by entering the code on remote works great.
Also entering code for display off and on works great,just the display brightness is not working.
9:51,time to call Mike..........................5min later:
Answer is,with the NEW display there is no dimming capabilities,plus the display will last longer,so...................ALL's GOOD.
Gee all I wanted was the tray problem fixed(which it is)  plus a new display,TYPICAL BRYSTON :thumb:.
In later models of the BCD-1 it was not possible anymore to dim the display. Quote is from an earlier thread.
WillyP
CanadianMaestro
« Reply #7 on: 25 Mar 2020, 06:02 pm »
WillyP
Thanks for clarify, Willy.   :thumb:
NekoAudio
    • Neko Audio LLC
« Reply #8 on: 25 Mar 2020, 06:47 pm »
I use LightDims to reduce the brightness of LEDs and displays. They have precut, cut-to-size, and different amounts of "dimming" in white, black, and silver.
Silverbullet
« Reply #9 on: 25 Mar 2020, 08:44 pm »
Don’t need to dim the display on my BCD-1. Only about five of the LED dots work.
WillyP
« Reply #10 on: 28 Mar 2020, 12:42 pm »
I have found the manual of the version of the BCD-1 where it was possible to dim the display. I have tried the codes for my BCD-3, but they didn’t work.
Still looking for a way to dim the display without a connection to the network. James, Mike or Stan?
WillyP
