Roon - USBridge - Holo Cyan
0 Members and 1 Guest are viewing this topic. Read 885 times.
Jflemelin
« on: 24 Mar 2020, 03:23 pm »
Anyone else using this config? Wondering if PS upgrade on the USBridge would do any good (or at least be worth the $ in sound Q increase).
rollo
  • Rollo Audio Consulting -
Re: Roon - USBridge - Holo Cyan
« Reply #1 on: 24 Mar 2020, 07:08 pm »
  If you can use iPeng check it out. We like the tonality and harmonics better than Roon.
charles
Jflemelin
« Reply #2 on: 24 Mar 2020, 09:19 pm »
charles
