Elac Debut F5.2 $463/pair
0 Members and 1 Guest are viewing this topic. Read 2614 times.
pinkfloyd4ever
« on: 15 Mar 2020, 04:02 pm »
Elac Debut 2.0 F5.2 Floorstanding Speaker, Black (Each) https://www.amazon.com/dp/B07B4WFWZF/ref=cm_sw_r_cp_api_i_BSKBEb1EGAHCC
stlrman
Re: Elac Debut F5.2 $463/pair
« Reply #1 on: 16 Mar 2020, 10:49 am »
My buddy has these . They sound amazing . I would say they are a bargain for 2 grand , or at least we’ll work 2k.
« Reply #2 on: 16 Mar 2020, 12:11 pm »
They are 3 ways with so small drivers, these 5'' drivers can cover 60Hz to 4kHz or more, disappointed.
stlrman
« Reply #3 on: 16 Mar 2020, 12:19 pm »
Add a sub or two , and you have great sounding speakers .
Letitroll98
  • Too loud is just right
« Reply #4 on: 16 Mar 2020, 02:01 pm »
There are three bass drivers, so the effective radiating area will be larger than a single 5" driver.
« Reply #5 on: 16 Mar 2020, 02:04 pm »
They use 3 ways xover, 1 tweeter, 1 mid range and 2 woofers.
Smartly the dont inform the xover freq cuts.
jmc207
« Reply #6 on: 16 Mar 2020, 03:54 pm »
Crossover specs, etc. are on the Elac page: https://www.elac.com/series/debut-2-0/f5-2/
Enclosure Type : 3 – Way Bass Reflex
Frequency Response: 42Hz – 35000Hz
Nominal Impedance: 6 Ohms
Sensitivity: 86db @2.83v/1m
Crossover Frequency: 90Hz/2200Hz
Max Power Input: 140 Watts
Tweeter: 1″ Cloth Dome
Woofer: Triple 5-1/4″ Aramid Fiber
Cabinet: CARB2 Rated MDF
Cabinet Finish: Black Ash Vinyl
Port: 3 x Dual Flared
Binding Posts: 5 – Way Metal
Dimensions (WxHxD) : 7.09″ x 40″ x 9.21″
« Reply #7 on: 17 Mar 2020, 01:00 am »
Thanks for posting, 90Hz is a usual cut for a sub or big woofer as 15'' :scratch:
