BP-20
0 Members and 1 Guest are viewing this topic. Read 814 times.
A.P.A
BP-20
« on: 14 Mar 2020, 12:01 pm »
Hey guys,Just about to purchase a used and in very good condition BP-20 with MPS-1 DC power supply.
Silly Question...
Is it possible to get a phono stage option installed if the DAC option is installed on a BP-20? or other Bryston preamps for that matter.
I took a look at the online manuals and don't see that both options are available for one preamp?
Is this possible?
A.P.A
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP-20
« Reply #1 on: 14 Mar 2020, 12:46 pm »
Silly Question...
Is this possible?
A.P.A
Hi
The BP20 can only have either a DAC or a Phono Stage but not both.
james
A.P.A
Re: BP-20
« Reply #2 on: 14 Mar 2020, 01:04 pm »
Hi
james
Thanks James for the quick reply. From what I observed both input upgrades are done at the same location on the pre amp. Must mean the circuitry was designed that way.
A.P.A
Re: BP-20
« Reply #3 on: 14 Mar 2020, 01:44 pm »
A.P.A
Yes correct.  The newer preamps like the BP17 can have both Phono and a DAC
james
