CD player mods -- Cary 306/200
0 Members and 1 Guest are viewing this topic. Read 3118 times.
Cens
« on: 16 Mar 2003, 04:14 am »
Hi!  I'm new here.  My Saturday-night fun ended too early so I'm thinking about how to tweak my toys (always dangerous to the pocket book :cry: -- need to drink more when I'm out so I go straight to sleep when I'm done).  Anyone out there doing quality mods to the Cary 306/200 cd player?  If so, any details on the mods and what they accomplish?  I love the player as it is, but since CD is my only source, I'm always looking to improve.
Regards!
http://www.caryaudio.com/products/audio/cd306200.shtml
Jay S
« Reply #1 on: 16 Mar 2003, 09:12 am »
My Cary 303/100 responded well to a power filter - if you don't have a good one yet then you may want to try that as it will be safe/non-invasive.  I spoke to a local dealer of LCAudio and Trichord clocks and he was very optimistic that an upgraded clock would help.
tropicalcb
« Reply #2 on: 16 Mar 2003, 12:33 pm »
gday cens......I don't know the specifics of your player, but the addition of a low jitter clock circuit as you mentioned is imho absolutely essential. There are a few brands out there such as audiocom, trichord, LC audio. If you want to roll your own try elso kwak's latest version 7...it is an ear-opening improvement!!   if you like the sonic flavor of your player as it is, it will improve all the things you like about it. He'll sell you a complted board but you can get most of the parts easily and a couple as samples from AD etc, so you just buy the little pcb and olay off him...(at a fraction of the cost and at least the same sonic improvements as the others).
   You should also give any add-on low jitter clock circuit its own little power supply, which can be done in a small space and for <$25...I have heard the diff with and without a sep supply and I reckon the go is a sep unreg'd but well-filtered supply...most good clock circuits have on-board regulation. email me privately if you want further info.....no I dont work for elso, but his circuit is excellent, cheap and is truly in the spirit of diy.
  You can also change supply caps (sub low z and selectively increase size...you dont need flavor-of-the-month boutique types to get better sonics) and coupling caps  and also sub ultra-fast, soft recovery type rectifier diodes for sonically obvious improvements.  check out audioasylum and diyaudio for details.
  Ive just gone through this mod path myself and turned a horrible/screechy digital sounding cheap cdp I picked up on ebay for bugger-all, into a very detailed, dimensional imaging source with sweet extended highs, very seductively listenable analogue-like mid range and fast, extended, very well defined and rivetting bottom end. The soundstage is bigger and individual sounds are easily identifiable and steady within their own part of the sound space. End result is a very enjoyable and engaging musical experience...its not perfect but in some ways I prefer it to my Linn/moddedRB300/Blue Point Special setup...and thats a real sonic compliment~~
   cheers........cb
Cens
Interesting
« Reply #3 on: 16 Mar 2003, 03:55 pm »
Thanks Jay S and tropicalcb.  I'm a tyro when it comes to modifying the innards of my equipment so probably wouldn't do any work inside an expensive CD player on my own :nono:.  That said, you've given me something to explore.
If I'm going to look into replacing the clock, anyone know of a site where I can get a better sense of the relative merits of the custom ones on the market?  I know about AudioAsylum, and I'll check out DIYAudio some more, but are there other, more concise ones (I like to be spoonfed)?  That way I can, in theory, get a sense of how they stack up relative to each other and to the one the Cary 306/200 uses (if I can figure out which one that is).
Regards
Cens
By the way...
« Reply #4 on: 16 Mar 2003, 03:58 pm »
...I'm using Shunyata Hydra to condition the power.  I haven't the foggiest idea of how it works, but it seems to work well.  I also use a TG Audio power cord.
Jay S
« Reply #5 on: 17 Mar 2003, 01:29 am »
From what I was told by a local shop that sells both, the LClock sounds a bit cleaner and more transparent than the Trichord, which is a bit warmer and more organic sounding.  You may want to check the forums on www.audiogon.com to see if there have been any clock comparisons.  AA should be a good source.
Since you've got the power angle covered, you may want to look into reasonably priced footers - isolation vs coupling, not sure which one will work better for you.
Have fun!
