0 Members and 1 Guest are viewing this topic. Read 2473 times.
It might be helpful if you tell folks your budget ($100? $500? $5000? $10k?).
Also it would be helpful to know what country or continent you are on, shipping overseas gets expensive.
I'd recommend the Pagoda or either the Lampizator Amber or one their higher end models like the TRP model. The Audio Mirror Dac also sounds like a winner.
If you could find a used Aqua La Scala, that should fit the bill.
