Greetings All!
0 Members and 1 Guest are viewing this topic. Read 503 times.
VinceT
Greetings All!
« on: 4 Mar 2020, 06:38 am »
This site is great
Been lurking for a while decided to join. Hoping to start building my own speakers in the future. Appreciate the support  :thumb: :thumb:
Re: Greetings All!
« Reply #1 on: 4 Mar 2020, 07:07 am »
Welcome Vince :thumb:
Re: Greetings All!
« Reply #2 on: 4 Mar 2020, 11:07 am »
Welcome!
Lots of DIY interest in speakers from new members lately.  Maybe you guys should get together.
DIY is great for hobbyists who have all needed tools and skills and are happy with 20 year old technology, but speaker design isn't as simply as most think, so recommend using a kit.  Secondly try to listen before you build (hard to do with any DIY project) and measurements just give a vague idea of how it'll sound.  Third unless you're an experienced cabinet builder recommend doing one at a time to check build-ability (will everything fit, can you get inside the cabinet to mount crossover/internal treatments, how will the finish look).  Finally realize that resale value of any DIY project will be quite low.
40 years ago did a partial speaker kit (a pair 6 cubic foot bass cabinets).  Had heard them previously.  Everything went well even though was pressed for time, until the veneering (veneering options were horrible back then) and lacked tools/skill to do the job right.  Enjoyed them for a few years but ended up giving them away.
Phil A
Re: Greetings All!
« Reply #3 on: 4 Mar 2020, 02:01 pm »
Welcome!
Re: Greetings All!
« Reply #4 on: 4 Mar 2020, 03:38 pm »
Greetings & Welcome to AC Vince   :thumb:
Wind Chaser
Re: Greetings All!
« Reply #5 on: 4 Mar 2020, 04:07 pm »
Welcome to Audio Circle.  :D
