BDP-2 - Can not update firmware
0 Members and 1 Guest are viewing this topic. Read 1274 times.
VISA
« on: 1 Mar 2020, 01:46 am »
Just hook up a Bryston BDP-2 to a benchmark DAC1.
the System shown:
S2.05 2014-07-11
Build: Manic Moose
MPD: 0.17.5
I try to update the firmware but nothing happen. Should I try flash CF card?
Re: BDP-2 - Can not update firmware
« Reply #1 on: 1 Mar 2020, 01:56 am »
Welcome, I will move this topic to the Bryston Circle.
unincognito
    • bryston.com
« Reply #2 on: 1 Mar 2020, 02:27 am »
the System shown:
S2.05 2014-07-11
Build: Manic Moose
MPD: 0.17.5
That version of the firmware the update firmware feature is broken due to change in service provider years ago.  Reflashing it using the documention that can be found at http://support.bryston.com will resolve the issue.  Or if you call us Monday to Thursday we can remote into a computer to access the BDP and fix the issue manually and perfo the update.
Chris
gbaby
« Reply #3 on: 1 Mar 2020, 02:58 am »
Chris
http://support.bryston.com/
Wow! I never knew that link existed. :o
VISA
« Reply #4 on: 1 Mar 2020, 04:00 pm »
FullRangeMan : Thanks.
VISA
« Reply #5 on: 1 Mar 2020, 04:16 pm »
Chris
Thanks for the link.
Just to be sure, to re-flash the card.
Follow the BDP Manual Manic Moose Install.pdf, right?
And should I use the CF card installed or should I use a brand new one?
VISA
VISA
« Reply #6 on: 15 Mar 2020, 09:31 pm »
Chris
Flashed to S2.32 then update to S2.42.
One more question, do I need to upgrade BDP-2's sound card to IAD if I want to play DSD?
