Tone Tubby 8" hemp cone, full range drivers - Dallas - $150
0 Members and 1 Guest are viewing this topic. Read 1286 times.
Dieterle Tool
  • I don't know what it is, but I wunt it.
I have used them in two applications and was impressed with both. I built plywood, bass reflex boxes for them and used them in my lab for test speakers. Then I mounted them in the wall, in the lab, for radio playback while I worked. Not much audiophile imaging in the second application but man do they sound like live music. I pulled them from the wall when I moved and they haven't been used in almost four years.
the basics:
-8" hempcone drivers from Tone Tubby
-8 ohm, ceramic (or ferrite) magnet
-paper accordion suspension and whizzer cone
-hefty, aluminum frames
specs (courtesy of the one and only, FullrangeMan):
VC 8 Ω
VC former 1'' Kapton CCA
Rated Freq Range 40-20kHz tested in iec60268-5 type A enclosure
SPL 94dB 1W/M 3.3ft enclosure, average 500-2500Hz 1W/M
Rated power 45W
Program power 90W
Fo 45Hz
Re 6.2 ohms
VAS 88L
MMS 12gr
XMAX 1.9mm
No 1.1%
QES 0.5
QMS 2.5
QTS 0.41
Magnet Ceramic 566gr 20oz
Net Weight 1.5kg 3.3lb
The drivers are in very good condition with no defects. They play loud and clear.
Price does not include PP and shipping. Please make a reasonable offer to your zip code.
Dieter
« Last Edit: 5 Jul 2021, 05:17 pm by Dieterle Tool »
Re: Tone Tubby 8" hemp cone, full range drivers - Dallas - $135
« Reply #1 on: 26 Feb 2020, 03:34 pm »
Hi,
Wonder if its suited to a big or small box. Do you have the TS parameters or the freq range chart to post here or PM me?
Dieterle Tool
« Reply #2 on: 27 Feb 2020, 08:56 pm »
I sure don't Gustavo. Using Audio Nirvana designs and being familiar with Omega's, I would think anywhere between a 1.5 cu/ft and 2.5 cu/ft box would work well. I had thought about a ported, floor standing size around 2.5 cu ft would have made a nice music machine. Especially with 2 or 4 subs!
-Dieter
« Reply #3 on: 27 Feb 2020, 11:29 pm »
After a search found some basic TS:
VC 8 Ω
Rated power 45W
Program power 90W
Fo 45Hz
Re 6.2 ohms
VAS 88L
MMS 12gr
XMAX 1.9mm
No 1.1%
QES 0.5
QMS 2.5
QTS 0.41
Dieterle Tool
« Reply #4 on: 28 Feb 2020, 11:08 am »
^ Thanks for the specs. Looks like I may have missed the magnet composition, ceramic not ferrite. I have updated my ad to reflect this.
-Dieter
« Reply #5 on: 28 Feb 2020, 02:55 pm »
I think ceramic and ferrite are the same thing.
Dieterle Tool
« Reply #6 on: 28 Feb 2020, 04:02 pm »
Sure enough... "The Ferrite permanent magnet is also known as a Ceramic Magnet and even as hard ferrite magnet. ... They are known as Ceramic Magnets because they are electrically insulating".
Learn something everyday.
-Dieter
Dieterle Tool
« Reply #7 on: 5 Apr 2020, 04:29 pm »
Adapted specs into original listing and up for bump.
Dieterle Tool
Re: Tone Tubby 8" hemp cone, full range drivers - Dallas - $150
« Reply #8 on: 5 Jul 2021, 05:18 pm »
Still have these...
