Tidal wont play through USB port- Windows 10
0 Members and 1 Guest are viewing this topic. Read 1566 times.
lokie
« on: 23 Feb 2020, 02:38 pm »
I cant get Tidal to play through the usb port on a Windows 10 laptop.
You tube will play no-proplem.
I can see and choose the USB/SPDIF convertor. Just can't get Tidal to play through it.
Any ideas?
Phil A
Re: Tidal wont play through USB port- Windows 10
« Reply #1 on: 23 Feb 2020, 03:06 pm »
A.P.A
« Reply #2 on: 23 Feb 2020, 06:06 pm »
Any ideas?
You may have go  through your bio settings on your windows 10 laptop to force audio out to the usb port
this might solve your problem..
lokie
« Reply #3 on: 23 Feb 2020, 06:18 pm »
bio settings??? That sounds scary. I already have a headache.
Phil A
« Reply #4 on: 23 Feb 2020, 06:29 pm »
https://learn.g2.com/windows-10-bios
I have my Windows 10 desktop setup to not allow things to make changes to my device and sometimes when I have an update I get a message in the notifications and then go in and allow that to happen.  There's all kinds of settings.  Not a Tiday user (already have too much music I haven't listened to).  That's why many audiophiles end up with players/streamers that don't deal with Windows 10 (e.g. Lumin/Aurender, etc.).
HAL
« Reply #5 on: 23 Feb 2020, 06:39 pm »
Try defaulting all Windows 10 audio output to the USB Audio device and see what happens.
You can try that through the sound settings in Win 10.
lokie
« Reply #6 on: 23 Feb 2020, 08:20 pm »
Yes... did that.
viggen
« Reply #7 on: 23 Feb 2020, 08:42 pm »
in Tidal settings, select "stream" and somewhere at the bottom you can select which device to output to.  It should either be "default" or whatever your usb device is.
avta
« Reply #8 on: 23 Feb 2020, 10:34 pm »
I’m sure APA was referring to BIOS settings. Have you tried uninstalling Tidal and reinstalling it?
