0 Members and 1 Guest are viewing this topic. Read 4031 times.
I tried Alnico and never looked back. Smooth high end, yet still detailed and defined.
The tendency of the Super 3i (narrow cabinet) to be a bit shouty on female vocals was why I sold them off some years ago. Since them, I have purchased and use the Super 7MKII and the CAM (narrow cabinet) and am very pleased. No shouty tendencies.
OK, so based on that, which models would you suggest for my set up?Thanks Alan
My experience is that the sound does warm up a bit as the cabinet gets bigger and wider. Each Omega driver has it's own strengths and weaknesses as do any speakers from any brand. The Alnicos are a bit smoother in much of the range where the RS5 can be a bit whispy. However, I find that in the highs, the opposite can occur. You just have to decide what trade offs you can find acceptable.You did mention that it happens when you turn it up...you aren't hearing amplifier clipping are you?I've got RS5's, 8's and Alnicos and I really do enjoy each of them for their unique strengths and prefer any of them to conventional speakers.
