SOLD. SOLD Intona USB 3.0 Super-Speed Isolator 5kV - Just released by Intona
0 Members and 1 Guest are viewing this topic. Read 515 times.
grannyring
$379 for package. Shipping is $15.
This is Intona’s newest and just released USB isolator. This unit is the fastest and top of the line model that sells for $509. My Acoustic BBQ DC cable sells for $150.
USB 3.0 SuperSpeed Isolator 5kV
Model 7055-D
USD 509.00
I used it to solve a slight ground loop buzz coming through the USB, but was absolutely taken on much much better my music sounded. This unit is a real gem. I have owned several high dollar USB reclockers and the like and this unit has had the most positive impact on my digital front end. Music flows with greater intimacy and realism. It was like I upgraded my dac in terms of benefit. Only selling because I am looking at buying an ethernet/fiber optic based Lumin x1 and will no longer need this.
I am a cable builder and will include a fantastic sounding DC cable should you decide to power the Intona with 5vdc from a linear power supply. You don’t need to use an LPS as the Intona can be run passive with great results. If you add a power supply, then you will enjoy some gains in impact and dynamics. I used the wonderful Duelund stranded and tinned wire for this cable - 16 gauge. It is double shielded and a great add on should you choose to get a linear power supply. I sell my DC cables for $150, but will include it for free to the buyer.
You can buy a nice LPS from Sonore/Small Green Computer that works with my cable.
https://www.smallgreencomputer.com/collections/accessories/products/5v-15v-linear-power-supply-15w?variant=30287557951522
Features
New: auxiliary power input
The secondary side may be powered by an external power feed with up to 2000mA for energy-hungry devices via Micro-USB. The power switching between internal and external supply is done automatically.
More features
Provides galvanic isolation to the USB bus
Compliant to USB 3.1 Gen 1, 3.0 SuperSpeed (5 GBps) and 2.0 Hi-Speed (480 MBps)
Backwards compatible to Full Speed and Low Speed
5kV RMS Safety Isolation
Advanced ESD protection
Works out of the box, no drivers needed
Transparent to host and device: wide compatibility to all operating systems, embedded systems and devices
Works also with hubs and extenders
Supports all USB-specific transfers and modes
Powered by USB bus, no separate power supply
Ultra-quiet power rail isolation for less noise in highly sensitive applications (LT3045)
up to 500mA output current on isolated side
up to 2000mA output current on isolated using the aux input
National compliances: FCC, CE, RCM, ICES-003
IP 54 Aluminum housing
Dimensions: 120 x 30 x 70 mm
 Reply to Ad
« Last Edit: 20 Feb 2020, 02:13 am by grannyring »
