New member introduction
0 Members and 1 Guest are viewing this topic. Read 734 times.
Epikplatypus
« on: 18 Feb 2020, 04:06 pm »
Hi all,
I'm a newbie to the audio space and looking for some recommendations - hence the need for an Audiocircle forum login and this introduction post!
I don't have any experience with high end systems or speakers, but I listen to a lot of music and really appreciate quality sound. For reference, the highest quality setup I have listened to is Infinity Beta 20's and a Pioneer A/V multi channel receiver, VSX-1014TX. That needs to change!
I look forward to learning more and hope to get a system picked out so I can start saving up.
Best Regards,
Epikplatypus
Wind Chaser
Re: New member introduction
« Reply #1 on: 18 Feb 2020, 05:21 pm »
Hi Epikplatypus,
Welcome to Audio Circle!
circleman
« Reply #2 on: 18 Feb 2020, 07:28 pm »
Welcome to AudioCircle.
cwazyirishman
« Reply #3 on: 18 Feb 2020, 08:01 pm »
Welcome as well, I just joined myself so good to see an active community.
Cheers!
« Reply #4 on: 18 Feb 2020, 09:46 pm »
Greetings & Welcome to AC EpikP   :thumb:
« Reply #5 on: 18 Feb 2020, 10:51 pm »
Welcome  :thumb:
Phil A
« Reply #6 on: 19 Feb 2020, 12:03 am »
Welcome!
Epikplatypus
« Reply #7 on: 19 Feb 2020, 02:31 am »
Thank you all!
« Reply #8 on: 19 Feb 2020, 12:59 pm »
Welcome!
There's never been a better time to get into quality audio.  Examples:
1.)  CD quality subscription streaming ($15-20 per month) opens the door to millions of albums and saves the cost of local storage;
2.)  Active speakers (like studio professionals use) are cheaper than passive speakers due to having the power amps built-in (a wonderful example is the $300/pair JBL 305 Mk2 that can fill a medium sized room or be used on a desktop);
3.)  Inexpensive DAC/preamps abound, the $470 Sabaj D5 being just one.  But perhaps a better product is the $550 NAD Node 2i which includes an operating system and eliminates the need for a computer (except as a control option).
This compact, simple, affordable system should satisfy for a long time and get you very far along the road to the high-end of audio.
