X-LS Encore kit crossover
0 Members and 1 Guest are viewing this topic. Read 1754 times.
DDK66
« on: 16 Feb 2020, 10:42 pm »
Just built one of my crossovers i know it needs more zip ties and some shrink tubing just wanted some one to check my work before i solder it together.
Re: X-LS Encore kit crossover
« Reply #1 on: 16 Feb 2020, 11:20 pm »
I will move this topic to The Lab Circle.
Danny Richie
    • http://www.gr-research.com
« Reply #2 on: 18 Feb 2020, 02:16 am »
Looks good, but you'll need to slide that heat shrink on before soldering it all up. You won't be able to get one on that negative lead where the resistor and inductor meet if you solder the connection ahead of it.
And you can post those stuff in our circle.
