0 Members and 2 Guests are viewing this topic. Read 4170 times.
After 9 years ownership, I'm still very happy with my Amadeus GTA, sound wise that is. As for operability, a little less. Its the darn belt, there just to fragile. Once I get one that works well, I tend to not touch it, therefore never playing my 45 speed disks. I see that the new Amadeus 254 GT has 33 1/3 to 45 RPM switching without touching the darn belt. Does anyone know if this (motor, PS or both) can be fitted on the regular Amadeus? The motor looks like it's the same size. ThanksRobert
I'll add that I always give mine a little "assist" to get it spinning initially.
I also do this when starting the motor, I also use a length of string for moving the belt when I change speeds, it seems to work fine. Another tweek I’m going to make is investing in a Linear Power supply, not for performance improvement but more for just getting rid of the switch mode PSU which is most probably polluting my mains supply. I will report back here when I’ve affected this change.
