0 Members and 1 Guest are viewing this topic. Read 5332 times.
Background: I have a Schiit Modi 3 AND a Schiit Modi 3 multibitRecently I upgraded to Tidal HiFi/Master quality.Afterwards it seemed like I was overdriving the amp and had to lower levels.Question: Is the added fidelity/information in the streams overdriving the capabilities of the DAC or am I just high?
What sampling rate are this Tidal HiFi/Master?If it is 24/192 and your DAC dont read this rate it will not ''overdriving'', he will just not work.
Well good question, I guess it matters if it is in "Master" or "HiFi" and according to Tidal's website:"HiFi audio is a superior sound but is still limited in its resolution—44.1 kHz /16 bit.TIDAL has partnered with MQA to deliver something infinitely better: an authenticated and unbroken version (typically 96 kHz / 24 bit) with the highest possible resolution—as flawless as it sounded in the mastering suite. And exactly as the artist intended it to sound."
Another way to put it: does the dynamic range of the fidelity require I upgrade my gear?
No. Do your headphone speakers are damaged?
Well no, if I back down the quality it seems like they are not overdriven, which seems odd, hence the post and the question. Note: Newbie
Seems your HP speakers are not able to withstand the greatest dynamics IMO. I though damaged or you have exceeded the power limit.
I modified my original post to include my main system specs. (Sorry, I didn't want to keep posting replies.) Would that apply to the Heresy speakers?
Is the downstream equipment actually being over-driven by the (clean) decoding of Hi Def signals? Or is the decoding machine unable to supply a clean signal when decoding Hi Def signal? (and you really just notice it when driving it hard) There is not clear way for US readers to know.Then some of the answers are less than reasonable. Optic cable as cause, gimme' a break.One point to note is the downstream equipment may be getting too much voltage from the decoding device. The inputs are getting overloaded.One way to CHECK THIS is to add some resistance between the components. You can add resistors if you have any skills. or buy some (senility makes me forget wtf they are called) but they are little RCA devices with a resistor inside to lower to strong a signal)ANyway, if you slap a pair of THOSE in, and find all is well. then you will KNOW the signal was overdriving the downstream equipment. Instead of guessing. If it changes nothing about how the sound starts to distort. Then it most likely is a fault in the decoding box.This is the only thing I can think of to check to help you find the actual reason.
Also where does MQA end at the DAC when you don't have a DAC that decodes MQA?Am I limited to a specific quality without a DAC that can decode MQA?
http://www.rothwellaudioproducts.co.uk/html/attenuators.html
