0 Members and 1 Guest are viewing this topic. Read 3691 times.
Is there a reason he only secured the driver into the baffle with two screws? Would that have any impact on performance?
Well, seeing how GR Research is currently not shipping any speakers based on BG Neo 10 due to driver "issues," I would ONLY buy them from trusted sources that test them. Hope GR Research can work with BG to come up with some reliable and well-measuring units soon
Could you tell us what "PHD" on the Klippel distortion graphs is?
And BG has been out of business for about three years or more now.
Ahh, that explains a few things. Guessing PE sources direct from former China factory now?cheers,AJSoundfield
erinh, I'm not shooting the messenger or questioning your ability to use the equipment. But measuring for distortion outside of an anechoic chamber will give you those inconsistent results. Even the manual that comes with our Clio system covers that issue. And it makes no sense for one or two drivers to show no distortion and be perfectly flat and few others are all over the place. If problems like that are real then they would be showing up in other ways and in other measurements, but they do not.BG Sold out to Chisty Digital and they now own the rights to those drivers. They were and still are being made by the same company in the Philippines. Availability has been spotty since they took over.
Hey Erin, I'm really glad to see you putting your measurements back online. Keep up the good work Could you tell us what "PHD" on the Klippel distortion graphs is?
